I have a avi file that i need to watermark(text) throughout the runtime.
Followed this guide https://forum.videohelp.com/threads/191496-Put-a-custom-watermark-on-your-video
The watermark is shown in the preview window, and the Output window pane on the main window, but it doesn't show in the output file.
Tried Avidemux, using the same pic created for the Virtualdub Mod tut. But Avidemux shows the black background.
I'm not used to doing avisynth scripts.
Any suggestions?
Results 1 to 13 of 13
Last edited by pras92; 2nd Apr 2013 at 16:31. Reason: To include "Solved" prefix in the title, just to make it easy for others.
I tried High compression, but it projected a file size for which i couldn't afford to buy hard disk space.
Then used Direct stream copy. -
Direct stream copy, will simply copy the video stream so it can't add/change anything.
But all the 3 methods other than DSC, Fast recompress, Normal recompress, Full processing mode gives the same huge output.
Isn't there a way to add text watermark to avi? -
Sure there is but if you select anything other than 'direct stream copy' you need to specify how Virtual Dub should recompress (Video->Compression) the content, the default setting is to save the new content uncompressed, which explains the huge output file size.
Yeah, i'm aware of that. I was afraid that i'd lose a sizeable amount quality on reducing the bitrate.
Though i'd like to give a try now. Thanks for reminding about the bit rate thing.
*Edit: How can i change the bitrate in virtualdub mod? I can't find the options. -
The target bitrate is a setting which should be part of the codec configuration of the codec which is used for recompression. (Video->Compression)
I already tried ffdshow and wasn't satisfied with the output quality. Other codecs are new to me, so i hesitated trying them.
I believe there are filters for importing external codecs such as x264 and AVC into virtualdub mod. Gonna try find some.
Thanks for your help. -
For now, i added xvid codec and it lets me change the bitrate. Now i can make the output (with the watermark, using Full processing mode) in reasonable size.
I'll try ffdshow (and that vfw thing) and other codecs for later use.
Thanks a lot for your help.
Interesting Build of VirtualDub/Mod
By Soopafresh in forum Video ConversionReplies: 8Last Post: 12th Oct 2012, 01:49 -
[SOLVED] Convert MOD video using ffmpeg for use with VirtualDub?
By yetanotherlogin in forum EditingReplies: 9Last Post: 13th May 2012, 20:25 -
Virtualdub Mod and Vobsub woes
By TheLaserdisc in forum Video ConversionReplies: 4Last Post: 30th Dec 2008, 01:03 -
problem with Dr Divx & VirtualDub Mod
By pcb in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2008, 14:59 -
is it possible to crop a WMV file with virtualdub mod?
By sumeshkri in forum EditingReplies: 4Last Post: 13th Nov 2008, 22:26
